ODDD1 saw on another post talk about bleed line restrictors, now since i will be replacing my bleed hose's due to old age, is it good idea to use those restrictors or leave as is.
Depends how old your motor is....from about 1995 up the restrictor is incorporated in the cylinder end fitting...pull a hose off one of them and see how large the hole in the fitting is, if it is less than .030"? you dont need em...otherwise put em in....
