She's leaking oil where the bottom section of the block/powerhead cover connects to the mid section.
VRO is connected and working, doesn't seam to be leaking from it or the hoses to and from.
Other than leaking, it is running great, only smokes upon start up then quites, so i supposed it not running to rich of a oil mix.
Question- Is it OK to continue to run the motor until i can find the time to get the leak fixed. Right now, I am running the boat every weekend.
Any ideas as to where it might be leaking from?
Thanks for the help!
