Re: V Drive?
And the important problem with Vdrives....take a motor, small block chev for example,turn it backwards in the boat and then shove it against the transom...now most of the stuff that needs service is on the front[now back] of the engine,you know, belts, water pumps,thermostats,fuel pumps, etc, etc....and you have worse than normal access to it! on top of this, the stuffing box for the prop shaft is now UNDER the motor! a hellish combination, by any marine tech's knuckle skin...
