Using Mityvac Manual Hand pump to pump gear oil into lower unit?
NYBo
Re: Using Mityvac Manual Hand pump to pump gear oil into lower unit?
The lubricant may be too viscous for the pump to handle. The proper gizmo is cheap enough.
robert graham
A hand pump is cheap enough and the best thing to use.
Bustedknuckle84
thanks guys for the replies i seen it at walmart for like 6 bucks i believe pickin one up today thanks
Bob_VT
Pump it in from the bottom hole until it comes out the top hole and then replace the top screw first ;)
