pecheux
- Jun 9, 2006
- 1,200
Have 2 OB's (Force & Jonhson) and would like to use the Johnson gas tank with the Force motor. Presently the Force OB is used with a Mercury presureless (vent on cap) gas tank.
The Johnson's original tank has built in pressure (auto vent) My question is: If the Jonhson tank is used with the Force motor, can that pressure have a negative effect on the Force carburator of gas pump or fueling system ?
Thank you,
Thank you,
