Bustedknuckle84
- Sep 29, 2010
- 421
I have a Mityvac Manual Hand Pump, it has a pressure or vacuum switch. im wondering can i hook up a line to the canister (fill it with gear oil) then run a line to the lower unit select pressure and pump gear oil into the lower unit?
my mity vac is similar to this one
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=MITMV8500&source=froogle&kw=MITMV8500
