Using an inflatable to get to shallow spots?
ricohman
I have been toying with the idea of buying a good size inflatable dinghy to tow behind my 22.5 ft Islander. I could then use this dinghy to row into some very shallow spots in the reeds where some big northern pike are lurking in the spring. The place I want to get into is quite large, but shallow and many underwater obstructions. The water is about 2-5 feet deep.
Sound like a dumb idea?
ricohman
Re: Using an inflatable to get to shallow spots?
Rowing would be optional. I could use a pole and make better time. I just wonder how well an inflatable would tow, even at low speeds. I can see it blowing upside down. Maybe a short tow rope?
hardwater fisherman
here they are using something called a bridle. im not sure if it is meant for high speed though.
AChotrod
With no motor on it I wouldnt try going very fast. Also if you are towing it why not get a cheap trolling motor for it? The motor and battery should hold it down better.
If youre talking about one of those tiny back packing inflatables just keep it in the boat uninflated and use a elec pump when you get to the spot. Deflate(some pumps will deflate also making it quick) and store when done. Get a collapsible paddle. This would be how I would go about it.
lncoop
Not a dumb idea at all, but for your purpose I think you'd be much happier with a SOT kayak. They have drawbacks like anything else, but a good quality yak will be considerably cheaper, easier to handle, last longer and perhaps most importantly be less susceptible to wind, which you'll find to be a huge hassle with a raft on flat water.
dingbat
+++1
