Re: Using a live well
Depending on the functions, you may or may not have all of these functions on your livewell.
1. Function where pump fills livewell up to an overflow outlet:
Water will continually circulate from the lake-into the livewell-back into the lake. (constant steady supply of fresh water).
This is good most any time if water temp is below 80 degrees.
2. Livewell pump Timer: Lets the pump do it's thing all the time, or just a certain intervals.
Intervals wide in cold water. More frequent as the water gets warmer. ON ALL THE TIME above 80 degrees.
3. Recirculate:
Once the livewell is full of water, this allows you to just re-circulate the water that is in it (no fresh lake water).
This is good in the summer/hot weather/hot water.
When you get to the lake in the morning, fill the livewell and close the valves so that no new water can get in. This will be the coolest water of the day. When you put a fish in there, turn it on recirculate, constant on. You can add a frozen bottle of water mid morning and then another early afternoon. That cooler water will not escape and hot water will not replace it on Recirculate.
NOW...I'm not a Rejuvinade salesman, nor do they sponsor me....but...THE STUFF WORKS. But, it's expensive and I'd say only a summertime livewell additive.
