using a glaze remover before new rings
Alumarine
I'm replacing the rings in my mercruiser 140 and was wondering if I should use one of those glaze removing tools that attach to a drill to prepare the cylinders. I'm using cast iron rings not moly.<br /><br />The cylinders currently look very good and are nice and smooth although I don't really know what glaze looks like.<br /><br />any help really appreciated.
Don S
Re: using a glaze remover before new rings
Shiny cylinder walls are what you DON'T want. The rings will never seat. <br />You do need to use a ball hone (best tool for the job) to put the cross hatch in the cylinders. This is what helps to seat the new rings and is a necessary procedure. Without it, you will use oil and loose compression, and have a lot of extra blow by.
Alumarine
Thanks again Don.<br />The cylinders don't look shiny, they are acrually dull in appearance but they are smooth.
Don S
Any time new rings are installed the cylinder should be honed.
weatherz
Another point Marc, is to use a ring groove cleaning tool on your pistons so the new rings will float smoothly.
Alumarine
wynter, thanks. I bought a ring groove cleaning tool, it worked well once I figured out which direction to mount the cutter.
