I bought a used V-6 150 recently to replace the failed original power on my old Lund fibreglass 19.5 ft runabout. It was cheap, it had good compression (115 psi +/- 2) and the tilt/trim worked. Once it was rigged on my boat, I found it difficult to start and wouldn't idle. Diagnosed a bad switch box and replaced both, checked and fixed the timing. Ran better but still not idling, so decided carb rebuild was needed. Engine serial # is G000308, which indicates 1994 year, ordered carb gasket kits accordingly. As I was rebuilding the carbs, I found the only gaskets that fit were the carb base to manifold and a few O-rings for jet access plugs. Turns out this engine has WH-35 carbs fitted, which I think were standard equipment on the late 80s V6s. Then I hunted around and found the engine block date: 08/88. Huh, looks like this one got a replacement powerhead and the original carbs came with it. Jets in place are .050 main, .060 off idle, .094 idle/vent.
When I search online for WH 35, I get a lot of references to 'Mercury V-135 hp', but looking up carb parts for 'V-150 hp' lists jets for WH-32, 35, 38, 40. I'm new to Merc so this is a bit confusing for me.
And so to my questions:
- are the WH-35 carbs intended for 135 hp?
- if yes, can they be re-jetted for more power?
- is the jetting I have currently correct for the WH-35?
- can someone direct me to an overview or cross reference chart of Merc carbs and engine HP ratings for this period?
