Re: Used TLDI - inspection
The 50 TLDI is a great outboard. Insist that you can hear it run. If it has high hours, there is a pump belt that could be replaced....but, that is routine maintenance. Like Elvin says- check the usual suspects....inspect it like you would any other used outboard....
They can act up if the battery is too small or toast....
Outside of that, they have been extremely reliable, efficient, and fun to run-
