Hi everyone. Am thinking to buy a spare outboard for my Palm Beach 173 white cap 2001. This hull weight 1375 pounds. I usually do fishing with my 3 sons and that should be no more than 600 pounds of us. Am actually using a johnson 70hp 2001 (thinking to change it to a 90hp). I think got a good deal on a yamaha 9.9, 2002. The main purpose of it would be to use it in case main motor fails. The second purpose (and don't know if am right or wrong) is to use it as a trolling motor. I do fishing at sea. Happens that have a side imaging fish finder and the turbulence of the main motor is bothering that side. (Am also working out other ways to attack this problem)
Got some questions
1. Is that yamaha too big or too small for this aplication?
2. I checked the manual for yamaha up to 1996 and it says yamaha wont publish specs for cylinder compression. Any body has an idea what would be close to good? It says the important thing is the difference between cylinders (15psi?). Top and bottom diff., but it has only two.
3. What speed should I expect to achieve? I know it depends on many factors, (wind, sea conditions. rpms,weight etc...). but a rough approx. will be fine.
Please, you remarks on any of those or all,will be appreciated.
Thanks, Luis.
Got some questions
Thanks, Luis.
