used lower unit?
whatsadixie
I need to replace my lower unit :( (1985 Johnson 120) and would like to know what year/hp I can use. Also where is a good place to get one (in DE, Northern VA, or net)?<br /><br />Thanks :)
whatsadixie
Re: used lower unit?
I need to add that the reason for replacing it, is that the lower unit (gear case) is badly corroded (When I bought the boat it had no anodes)
Dhadley
I believe the 1985 had the gearcase that was the size of the V6 but a little different gear ratio. It took the 14 thru 15" diameter props. You can replace it with a V4 case and a V4 prop. Same bolt pattern. <br /><br />If you have trouble finding one call Jack at Superior marine at 800-338-9281.<br /><br />Good luck!
