There's no way an 18' AL fishing or runabout boat would be rated as low as 70 HP. I have an 18'r that is rated at 140 and a 16'r rated for 70. On an 18' boat I would not go under a 90 but a 115 would be best all around.
An Aluminum Fishing/Runabout like a Starcraft and an Aluminum utility boat are two very different things. Advising that people well exceed the capacity plate is simply irresponsible.
Seriously shrew? I usually ignore posts like yours... and probably should again.![]()
I agree with shrew. How can anyone blindly make a hp recommendation when no-one knows what type of boat the OP has?
I guess I'm reading his post and getting something different.
I think the OP is saying he has a big Triton and is wanting to down size to an aluminum boat that he doesn't have yet and is shopping around for.
My advice and opinion for the OP's aluminum boat he's looking to buy is to not go low on power and I gave him the ratings on my boats that I own as an example... not for a motor on a boat that he doesn't have.
Guess that's totally irresponsible.![]()
Sorry, but recommending that people exceed the manufacturer's HP rating is irresponsible at best.
For one thing, the game wardens in many states will write a ticket for a large fine if you are grossly overpowered.
For another, any accident with the overpowered boat will lead to the overpowered boat owner being in for zero insurance coverage and lots of liability. The owner can also be charged with criminal negligence and any injury/death could be charged as a felony.
Nope... don't do it.
Result of being in the recommended power range and NOT at the max limit? You may not have as high a top speed, especially at full load. But speed capability is proportional to HP CUBED.
With all else equal, to double speed you need 8X power.
Appx 30% less than max rated HP is going to just be a few MPH difference from max rated HP.
But the lower power engine is usually lighter... allowing more useful load or higher performance at the same HP due to the reduced weight resulting in less drag. YOU MIGHT ACTUALLY BE FASTER with the lighter engine.
Prop selection can make a larger difference than the added HP...
Saying that 75% of HP rating is generally recommended is merely one (or several) person's opinion. There is no boating organization that makes that an official policy or suggestion.
