I need a assembly drawing for a (u.s. marine) shift and trottle contrl box. I disassemled the box because trim and tilt would not go up, I found a broken wire and repaired it, it worsks fine. the problem is assembling the shift lever with the 3 wires from the trim and tilt, I cannot figure out the proper routing of the 3 wires so they won't get damaged. Can anyone help me ? I would certainly appreciate it. Thank You, Ray
