upper shift shaft seal kit
Jcris
I recently replaced the bushings and seals on the upper shift shaft and am wondering If I used the correct parts. The kit I used has 2 seals that are both installed below the upper (smaller ) brass bushing. There appears to be a kit that has a seal in the upper and lower bushing. Take a look at the link. Is this an upgrade to an older design?
Jcris
Jcris
Yes that's correct Terry,
The seals should be on the upper bushing. I'm still getting used to the names and location of things . The upgrade does look like a better design. And they are called out as suitable for gen 2 drives
Thanks,
Jcris
achris
More fish than mountain goat
Yep. Same kit works in MC-1, R, MR, Alpha One and Alpha One gen II. The upper bushing carries the 2 seals. Both seals face the same way, down. The lower bushing is a very loose fit, I have never bothered replacing one.
