alpha 1 Gen II ....I am replacing the upper shift shaft seal and bushing and have a question on what direction should the seals be installed -currently the bottom seal is facing down with the face down toward the prop and the spring side facing up towards the bellows. Now back years ago the side of the spring was the side that was holding the liquid in or out..example -I replaced the seals on an old Jonson outboard and the seals went back to back -the spring faced in to hold the oil in and the outer seal spring side faced out to hold the water out - Have seals changed? I would think you would want the spring side of this seal facing down towards the prop to hold the water out
I hope I explained this clearly
