I have a 1968 18 HP Evinrude. I need to replace the upper bearing seal and have seen posts on here describing a drill and two sheet metal screw method of removing the seal.
If I drill into the upper seal, how much space is between the seal and bearing underneath? I'm assuming when you drive in the sheet metal screws, you only want them in about one turn or so.
