Hey guy's, i just removed the lower unit on this '87 mariner 150 to inspect the water pump and noticed a lot of play in the driveshaft. It seems the bearing is loose in the housing causing a lot of side play in the driveshaft and also quite a bit of up and down movement. The bearing is tight on the shaft. Is this normal or do I need to look at replacing the lower unit housing or is there something else that can be done to solve this problem? All advice greatly appreciated on disassembly and reassembly of the driveshaft unit.Thanks , Jimmy
