It's a 2 stroke and the weight is 330lbsthat boat is only 16' long
not only does the placard list max hp, it also implies a max motor weight limit.
So a 2 cycle,70 hp johnson weighs 250lbs. A 75 hp 2000 model 2 cycle can't weigh much more.
4 cycle motors weigh more in comparison.
How much does that 90 weigh......just stuff to consider...
It is a 4v but I honestly don't know about looper or crossflowI will assume the 90 is a V4, as 330lbs is what the later V4 90 weighed. Is it a Crossflow or a Looper?
The 70 has been giving me issues and no mechanic has been able to correct it. With the 70 I get around 31mph on glass water. However it's a wide boat. Almost 90 in beam.I have a 16' Sylvan side console that is rated for 80 hp...I have a 40 hp 2 stroke on it, 195 lbs....could not imagine a 330 lb motor on the back....when I stand back on the transom (165 lbs) I don't have much freeboard at the transom!! You might stand back there and see how your does....what is wrong with your 70 hp ? I get 31 mph from my 40....
Do you have a Picture of it?It is a 4v but I honestly don't know about looper or crossflow
Makes sense...stand on the transom straddling your current motor and see how the extra weight lowers the transom, that will show if the weight would be an issue !The 70 has been giving me issues and no mechanic has been able to correct it. With the 70 I get around 31mph on glass water. However it's a wide boat. Almost 90 in beam.
Wide beam is a big plus. 20", not 15" transom engine mounting height is also a big plus. Moving some weight forward can help to mitigate the extra weight....side console vs tiller steering is another big plus....would think that is how your boat is arranged. If you had a front deck with controls at a front seat a bigger plus. As jimmbo suggested, a few pictures of interior layout and hull shape would help us to help you.
I was suggesting Pictures of the motor, to determine if it was Crossflow or a LooperWide beam is a big plus. 20", not 15" transom engine mounting height is also a big plus. Moving some weight forward can help to mitigate the extra weight....side console vs tiller steering is another big plus....would think that is how your boat is arranged. If you had a front deck with controls at a front seat a bigger plus. As jimmbo suggested, a few pictures of interior layout and hull shape would help us to help you.
Wow...that is a wide boat...nice !!
