Mark42
- Oct 8, 2003
- 9,334
The original trailer springs flattened out. Guess the upgrades have pushed the weight over the capacity of the springs. A quick stop at the local truck scale shows the trailer weighs 1400 lbs and its rating is 1200. I checked the axle and it has a rating of 1600lbs, so I bought a pair of C hook springs rated at 2000 lbs and installed them tonight. Only took 2 hours!<br /><br />That should hold me until next year when I install an axle rated for 2000 lbs and some C rated tires and I'll call it done.<br /><br />I did take the time to check the bearings and they look great, but more importantly is that there was no water inside the inner bearing seal. Guess those Bearing Buddies are doing their job.<br /><br />Also put TripleGuard grease on all the pivot points and bearing surfaces. Took it out for a test drive and it was nice to hear a quiet trailer! No squeeks! Bet that lasts until the next time I launch the boat.
