Bustedknuckle84
- Sep 29, 2010
- 421
Did a waterpump replacement now having the following problem. In the pics youll see that while mounting the lower unti back up around the shift shaft is cracking. I made sure the lower unit was in foward also the remote controller was in foward. The lower unit only get so far (see the gap in the pic) before i here the cracking from the shift rod hole.
I verified that turning the flywheel turns the prop.
Is there just to much damage to keep the shift rod splines coupler from comin up through that hole? *added more pics on 2nd post*
