mikel1291979
- Jun 28, 2010
- 106
I am fairly certain my transom seal is leaking. After installing the new motor I went to put it in the water yesterday. 5 minutes in the water and I had several gallons of water in the bilge. I never even started the motor. When I pulled the boat back out of the lake, water was coming out of the transom assembly area. Hard to explain exactly, but just above where the trim hoses bolt in there are holes on either side of the assembly. Looks like they are vents of a sort and they seem to be inline with the exhaust boot.
It looks like if I pull the drive, motor, and steering off there are only 4 main bolts and a handful of smaller ones holding the transom assembly on. Does anyone know if this is the case? If so it looks like a fairly easy job once the motor and drive come out.
The transom is good. I core sampled it and went after it with an awl. No soft spots anywhere.
