Hi I have been having problem with this motor for a couple of years. Its only got worse as of late last season. I have repalced all the fuel lines to the carb and all the T's Thinking it was apin hole. I finally started tracking it closly. It use to only happen after a 30 minute run, now it happen more. I have removed the air intake to trouble shoot this problem. The motor runs fine for the first run then after going slow it boggs and stalls out. Heres what I found.It seems to only be running on the #2 and #3 cylinders at this time till you get more timming advancement from throttle movement and then #1 chimes in you can clearly here this.Its do to pooling of fuel in the throat of the # 1 carb its fouling the #1 plug at slow speed, or at idle or low rpms say 1500 and below when you advance the throttle she quits. If left at idle for more than 5 minutes it will cause the #1 plug to foul if the throttle is advanced she quits. I have a carb kit to rebuild the carb. What sould I be looking for that would cause the excess fuel. Is this a float problem? I have synk all the carbs so I thing its not that. I can see excess fuel spray even at idle?<br />steve
