180Fisherman
- Oct 6, 2009
- 276
OK I found it. The prop says 14x17. It's aluminium and while old and pretty beat up at the edges there are no significant chunks taken out of it. Although judging by one of the reply posts I should already be over propped. Do props lose pitch over time from the forces of the water? Should I go up more? Pitch or diameter?
I have this boat (data taken from NADA site):
Boats and Personal Watercraft
2000 WELLCRAFT MARINE CORP
A GENMAR COMPANY
FISHERMAN 180(***)
Outboard Boats
Length: 18'
Model Name/Description: FISHERMAN 180(***)
Boat Type: Outboard Boats
Hull Material: Fiberglass
Beam: 7' 11"
Engine: N/A
Net Weight: 2780
(***)INCLUDES THE VALUE OF THE TRAILER. -- APPLY NOTE WITH * ONLY WHEN THERE IS AN ASTERISK(S) FOLLOWING THE MODEL NAME.
The boat's manual cites the weight the same but a 2800 net weight seem way high for an 18' center console. Might that include the trailer or engine?
Anyway it's powered by a 2000 Johnson 115 V4 looper that runs great and the performance is adequate but wot I'm getting 6K rpms which is higher than what I have found to be the quoted max rpm range. Speed I'd guess is about 40mph. I'd like to bring max rpm down closer to 5500 rpms and in doin so I'd hope for a little more cruising speed as say 4500 rpms as with a larger or higher pitch prop I should be pushing a bit more water. Unfortunately I have no idea what prop I have now.
Is this enough information to determine a good starting point for determining what size and pitch prop I need to achieve my goal?
A GENMAR COMPANY
FISHERMAN 180(***)
Outboard Boats
Length: 18'
Beam: 7' 11"
Engine: N/A
Net Weight: 2780
