Re: *UPDATE* 1963 Evinrude Fisherman 5.5HP keeps dying after a few seconds
I think Tom is most likely right about the overheating. Another possibility is a problem with the fuel supply system. An easy way to check this is to pump the primer bulb when it's acting up. If the engine doesn't change it's running then it's fine. If it improves look for a weak fuel pump, fuel line restriction (clogged filter for example), air leaks at the fuel line fittings - particulairly the fuel line connector fittings. <br /><br />A little decoding:<br />Pen Oil - Penetrating oil (to loosen stuck fasteners)<br />Ignition boot kit - replacement 'ends' for the spark plug wires where they connect to the spark plugs.<br />PH gasket - Power Head gasket. Replacing the impeller requires removing the power head (engine proper) to disconnect the shift linkage. A proper job of reinstalling the powerhead requires a new gasket.<br />Type M adhesive - OMC product used to seal gaskets.<br />CRC - Corrosion inhibiting spray. Good stuff for spraying down the powerhead.<br />Torch - ?? Possibly used a torch to loosen some stuck bolts. This is almost always necessary with old salt-water motors.<br />Bleeder Hose - I belive this is a recirulation hose, which recirculates oil from the bottom bearing to the top.<br />Shear pin - this is a little replaceable stainless pin that drives the propeller when the propshaft turns. It's purpose is to shear if the propeller strikes an underwater object while running. It may have been replaced with a nail or something else at one time (as they often are). It is good practice to carry spares and the tools required to replace it.
