Well, it seems I can't get one little thing fixed without another little thing popping up. For the record, I have an 86 Merc 75hp 4cyl with PTT. Last time out, I noticed the motor would barely tilt up. So I got it home and found that I had blown the top seal on the tilt pistion. Okay, so I finally got that fixed, but part of the procedure when putting it back together was to "press the UP to extend the tilt piston to the fully raised position to reconnect to the motor". Well, this is when I found that the "UP" no longer worked. I had just put a new controller on it, with another switch, and it worked just fine before I went to work on the tilt piston.
So, I thought it might be the switch on the controller, since it was a little "rickety" when pressing it. I took the whole thing apart and cleaned it, and still no dice. I am able to wire across the big nodes on the upper solenoid and raise the motor that way, but I cannot get the switch to work at all. On my solenoid, there are the two big nodes with with the red "positive" big thick cable, and the big thick black cable (Negative or ground) on the top of the solenoid. This is what I can "short" to raise the motor. On the side of the solenoid is the small blue wire that goes to the controller and another ground.
So, since the solenoid works (I can short it manually), but there is no apparent power to the controller, does this mean the solenoid is shot, or is there something else I can try? As usual, I appreciate any help.
