Hubby put new waterpump/impellar(again), new head gaskets, new coils, water deflectors and compression is back up to 100 on three cylinders. The bottom right cylinder is questionable because the threaded insert came out on the plug before we took the head off to replace the gasket. Apparently a previous owner stripped a plug and added a insert. Hubby tried to get the threaded insert off the plug to no avail so just screwed it back in (new plug attached). It was very difficult to get back in. The threading is a little off due to "trying" to remove it off the plug. So we didn't check compression on that cylinder after we replaced the heads. This may be a dumb blonde question but anyway of checking compression without taking the plug out? We haven't began the steering problem yet but jotted down the info. given to us on this wonderful board! Thanks again ! We'll give further up-dates soon I hope
Wifey
