Unsure of what Carbs belong on motor , 1980's Merc 50hp Serial number 5534190
DamianJP
Serial Number 5534190 , 1980's (Unsure of age) Mercury 50HP.
What Carbs belong on this motor , What part number(s) ?
Set of carbs that came on the motor when bought....
617A1 on one side BA3BT814 on other side
Bottom
6517 on one side BA3B814 on other side
He got a siezed extra engine that came with the working one(above). It is the same motor just younger. (Ill try and get a serial for this one too)
6517A7 & BA3DT201
Bottom
6517A8 & BA3D151
We have a Gasket/Seal carb kit x2. We want to find out what belongs on the Serial Number 5534190 motor and rebuild that set.
Thanks,
DamianJP
Chris1956
Re: Unsure of what Carbs belong on motor , 1980's Merc 50hp Serial number 5534190
OK, Serial number indicates an '80 or '81. The '80 model shows a carb of 6517A61 or 6517A62. These are center bowl with built in fuel pumps. Crowleymarine did not have a listing for an '81 model.
Sorry, not much help here.
DamianJP
Yeah I saw the same numbers but was hopping someone knew mabey if these would interchange somehow or something. Before I post here I check Iboats, Crowley, boats dot net, Marine engine , Mercury parts , mercruiserparts.com and others.
But im stumped, the boats runs fine with the ...
6517A7 & BA3DT201
Bottom
6517A8 & BA3D151
On it but it has a problem where it will idle fine for aittle bit then start to stumble and fail until you pump the primer abit. Other than that the motor has no problems with take off , mid range , high RPM areas.
Carbs finally got gummed up so I wanted to make sure what belonged on the motor and put the kit into that set. Which set of what we have would you say to rebuild?
EDIT:
The carbs that came with the engine have .096 idle jets.
The carbs from donor engine have .092 idle jets.
Crowley says..
.096 for united states 5796395 and below
.092 for united states 5796396 and up
He was using the donor carbs (.092's) , so with the 5534190 # he should be using the .096's. Might be why the idle was off and had to keep messing with the primer to hold a idle every no and again. Think so?
DamianJP
oldman570
Very well could be the trouble. What is the SR# of the donor motor? The PO might have changed the carbs around rather than rebuilding the ones that was on the motor. Oldman570
DamianJP
Well from what you say, that the motor takes... "The '80 model shows a carb of 6517A61 or 6517A62."
6517A61 and 6517A62
1)Is that the Top and Bottom carb? Or two different kinds as sets?
2) Are any of the sets from the numbers I gave compatible with the motor?
Like I said they run fine but have a idle issue which I believe to be fixable by using the missing brass baffle (That were in the other carbs).
And using the .096 jets. (Instead of the .092 which he was using, and had the idle trouble)
Thanks,
DamianJP
