ziggy
- Jun 30, 2004
- 7,473
don't know if i got a problem.
removed my drive to store in basement a few weeks ago. did some bellows inspection from the inside after drive removal. found lots of gimble brg. grease (green in color) up by the gimble brg. that didn't surprise me, i lub it probably more often than needed. found some blue spline grease up by the gimble brg. that didn't surprise me, i run an alignment check pre and end season + lub up the shaft with spline grease too. so that don't surprise me. what did surprise me was brown liquid in the most aft crease of the bellows. just that one crease. it looked like semi dirty motor oil. no water for sure. bellows look serviceable though i believe them to be getting out there for to much time on them. 5 years. drive always stored down, drive removed for winter layup w/bell housing covered. i use mercruiser high performance gear lub. the aqua green stuff. just inspected my gear lub today in the drive. drive lub was right at the bottom of the vent hole, just like i left it pre season this spring. still green. removed drain plug and let a little drip out. darker green than came out of the bottle, but no water, no metal fragments.
so....
any ideas on the brown, motor oil looking liquid in my aft crease of my bellows? just that last crease...
my idea is that it's 2-4-c that's separated. i use plenty of that too on the drive snout, shift shaft slide, shift shaft slide cavity in the drive, shift shaft lever. so my notion is that i don't have any issue. thought i'd run this across the board and see if i'm thinking proper though. or other ideas as to what the liquid may be. point of the above description is. i don't use any brown liquid in my drive, short of 2-4-c. but it's not liquid. the color of this liquid is about that of 2-4-c though.. sorry no photos in this case.. i blew that part..
so....
