After launch this spring, I noticed that the starboard manifold and riser are getting more hot than the port side. The heat is not so bad that I can't hold my hand on them, but the one side is considerably hotter. (The engine runs at normal temp.) I removed the risers and there was no obstruction or rust in the water jackets. I then removed the water hoses leading from the thermostat, and they likewise seem fine (unobstructed). The water goes straight from the thermostat to the manifolds, so it would seem to me that this could only be an obstuction (which it doesn't appear to be) or the one side is somehow producing more heat than the other. Is this possible? What else should I look at? I have a 1997 raw water cooled Merc 5.7 (carb), Alpha One outdrive. Thanks.
