Hi: Re: a 1985 Mercury 90 HP Inline 6, I'm trying to start this engine with just the chopped off wire harness, no controls. I have the manuel's wire diagram* but it doesn't explain what happens to the wires once they enter the ignition switch (which I don't have) Can you please finish and/or correct the following. It should be viewed from the cranking/start up point of view. Thanks.
*Ref: Selco Appendix pg A-40, & A-48
Yellow w/blk tracer, Choke, energized w/+12 v upon startup/cranking
Yellow w/red tracer, Starter solenoid, energized w/+12v upon cranking
Red, Starter solenoid/rectifier, energized w/+12v constantly
Gray, Rectifier, ???????
Black/yellow tracer, CDI, Grounded w/-12v constantly
Solid Black, Starter solenoid, Grounded w/-12v constantly
Solid Brown, ????, ??????
Solid Violet, ?????, ??????
