Under floor fuel tank placement
skiers5
G'day all hope the weather has been kind enough to let you out on the water. OK my question is, should I position a 90ltr under floor tank as close to mid point of the hull to help balance out the addition of a second battery or keep it in its original position toward the stern. My positioning will vary 40-50 centimeters
Full tank and 3 guys fishing out the back has the tansom sitting a little lower in the deep blue than i think it should be. The idea of carrying 2 removable 10ltr fuel drums up front is an idea for when I want to go out a bit further.
Does any one have any suggestions or experience in balancing out a hull, its a 5mtr Seafarer V-Sea cuddy cab with a 115 Johnson if that helps.
Thank you for any suggestions info
Dean Cameron
