93 225TLRR
Had to replace WP and also replaced the pressure relief valve. In the process stripped 1 screw on the PRV. I retapped to 7 MM and it went OK. I had to remove the CDI to get to the bolt hole in the outer exhaust cover to retap. When I had everything back together, I put on the muff and it fired right up but very rough and smoking exhaust and oil/water covered ground.
I don't know what I could have done to cause this. I have rechecked all bullet connections and ground connections. I don't have a remote starter and not sure how to make one to check spark. Fuel pumps are new.
Once started it quickly dies and I can not keep it ideling.
Where do I start??? It's either a fuel or ignition problem. I can't help but feel something changed during this repair. All oil components seem to be operating right. No broken links and oil tanks properly full.
Please help.
Please help.
