I am having an idle problem with my 1998 Mercruiser 3.0. I recently began having problems getting my engine to idle. It seems to run fine above idle and at WOT, but when I return throttle to idle position, it usually dies. When in neutral just above idle, the idle is not constant, it gradually goes all over the place, between 700 and around 1700. When it stalls, I have to give it full throttle and it is hard to start. When it does start, there is black smoke from exhaust momentarily.<br /> I also recently had a rise in temperature which began around the same time as the idling problem, so I replaced the water pump, but it did not help. After a 3/4 to full throttle run of a couple of miles, the temp begins to climb to around 170, and when I slow down to just above getting on plane, it climbs above that. If I immediately stop and let it run in neutral just above idle it immediately cools back down, but the temp use to be around 150, and now stays around 160. Can the idle and temp problems be related? Where do I start? Thanks for any help!
