lonewolf41
- Jun 28, 2013
- 139
I put this rebuilt motor into my boat in 2017 and it sat all last year while we moved. Now, while it runs well, it seems to have low power and tops out at 4300 RPM (scan tool and tach both read the same). I have a Rinda techmate scan tool (picture attached) so I hooked it up to see what it says. It has 5 codes stored. I want to clear those codes as they could be old from where I was installing the motor and hooking things up etc. I want to be sure I have fresh data.
After it tells me the codes, it asks me if I want to clear the codes. I say yes and it says "codes erased", but the codes are still there when I read them again right away. This happens while I am out on the water idling, but it also happens in my driveway if I just have the ignition turned on and the engine is not running. I can't imagine it would set codes again (and the same codes at that) if it hadn't been run since the codes were cleared so I am assuming that they are not getting cleared.
I don't know if something is wrong with my scan tool, I don't know how to use it, my ECM is defective, or what is going on. Anyone have experience with one of these that can verify that what I am doing is what should clear the codes? Any other way to clear the codes? The tool says the ECM is an MEFI 3. The ECM came with the motor.
Thanks.
Thanks.
