Re: umm can fix a jet but not my boat lol.30 hp
Sounds like the shift linkage, there should be a little cover with two screws holding it on. That the cover off and remove the two bolts (or screws in some cases). This will disconnect the linkage and it should drop right out. And the "prop section" is called the lower unit or LU on this disscusion board sometimes.<br /><br />If that doesn't do it, there may be a bolt under the trim tab(Looks like a little rudder) you may have to remove.
