Greetings - sure many of you have seen my other threads about my little boat project, well it doesn't end just with the boat and the trailer..<br /><br />My engine is a mid 80's Mercury 9.9 that unfortunately sat outside in the cold for 2 years (freezing temperatures reach 0 here). I assumed it was stored in a basement where I left it but found out later it was placed on my boat where I stored it (brothers house). Needless to say, I finally wanted to do something with it and after many days..was able to get it started and running to the point it was when I purchased the boat used...kinda rough with the choke wide open...<br />Well - like everything in life, time passed and I didn't do much with it. I left it in my storage area that is semi-heated but during some of the REALLY cold nights I am afraid that maybe it got damaged. Luckily NOW I have ALOT of room in my very own basement and house - BUT alas..that's not my current problem..<br /><br />The issue: Before I went to work today on my transom, I figured I should verify the engine still works etc and didn't want to scratch up my new transom work while I pulled on my engine 1000 times. <br />Luckily, and much to my amazement, A spray of some carb cleaner - some fresh gas and she popped after the 3rd pull. I pulled about 10 more times and NOTHING. I waited a few mintues, pulled it ONE time and it started right up! I was pretty happy...but then it stalled in about 5 seconds.<br /><br />After several tugging sessions, I was able to get her running reliabily (seemingly even more than when I last used it) - but after about 20 seconds, I noticed something...<br />NO WATER COMING OUT!!!!!<br /><br />I immediately shut it down and looked all over the place. Underneath the fin and just above the prop is a metal grate where I BELIEVE the water comes in. I looked ALL over the shaft looking below the mark on the boat where the water line was left from previous scum..and found nothing else.<br /><br />SO I started it up again, and even popped it into drive for a nanosecond hoping I would see water shooting from the top...nothing.<br /><br />I shut it down, and my neighbor said he saw water coming out in a stream at the very bottom of the fin of the engine. There was grease throughout the water tub - and smoke was coming out all over the shaft wherever there were holes. NOT pouring out, but some smoke coming out , and even through the prop!!!! (I pulled it out of the water immediately after stopping it if that helps)<br /><br />I only ran if for about 10 - 20 second intervals and it's pretty windy and chilly here today so I hope that wasn't bad. I remember that not much water used to come out at first when I started this long ago, and until I actually started going forward, it didn't pour out fast and hard until then.<br /><br /><br />ALSO - when i squeezed the fuel bulb, I noticed fuel shooting from the side of a metal plate where there is a gasket. It's wierd however as the plate covers something that actually has a notch below it...that's where it is coming out..almost like a 'overfull' return or something? The picture doesn't show the notch under the plate, and it definetely looks machined and not damage, but I am wondering if this should be like this (which I doubt) or if it's just the gasket.<br /><br />Also - what am I looking at for possibilties with this water issue..is this bad and expensive?<br /><br />Thanks guys...again...to all...I appreciate it!<br /><br /> squirting fuel... <br /><br /> rear of engine...showing where water normally comes out.. <br /><br /> another photo..
