UC-12X Ignition coil, resistances?
foilled
Hello for omc 5.7 1987 what would the resistance specifications be for a Blue Streak UC-12X ignition coil be? For primary im getting 1.2 ohms and for secondary im getting 9000ohms.
Ayuh,..... What's the issue yer tryin' to fix,..??
I ask, 'cause it's rarely to never the coil,.......
foilled
Im getting a bunch of soot thats exits with exhaust water. Theres tons when im running it at home on the muffs. It must be running real rich or something its not oil from engine or outdrive. Its comes out with exhaust water. Any ideas? I have another post up with some photos.
Ayuh,..... You've got a Carb problem, not the ignition,.....
foilled
Ayuh,..... I imagine a good rebuild, 'n tune oughta cure the issue,.....
Sounds like it's runnin' way rich,.....
Thanks. Ive never taken a carb apart, i feel like i could do easily though, should i replace floats while in there or just do the kit?
Ayuh,..... I don't buy the floats, unless I find a problem with 'em,......
foilled
Bump.
Does anyone know the specifications on this coil that I should be in? On this YouTube video, in comments poster said I need to replace my coil but has a different one then me, https://youtu.be/fLIfX1MvI1I. I’m trying to figure out if I need to replace. Then on this site I found a new coil of my exact one and specifications are slightly out of range from my used one I tested. Any ideas?
https://www.summitracing.com/parts/smp-uc12x
is my coil even marine qualified?
Ayuh,..... If the motor was runnin', there's nothin' wrong with yer coil,.....
Have ya rebuilt the carb,..??
foilled
Carb rebuilt. Trying to find low wot rpm cause or if it’s just wrong prop. The list you shared had ignition system on it, trying to make sure everything is in order
