u-Joint Lubrication
FreeBeeTony
I recently greased the u-jonts on my 165 Mercruiser. When I did, I only saw grease ooze out of 1 of the 4 corners on each u-joint. Is this normal? Or should I see graese come out of aLL 4 corners?
crazy charlie
Re: u-Joint Lubrication
It should come out of all of them.What kind od condition are they in,you may be able to unload a can of brakleen on them and clean them up and then try the grease again. Charlie
FreeBeeTony
They don't appear to be in bad condition, no rust or corrosion. What is "brakleen"?
crazy charlie
Brake parts cleaner.It gets all the old grease and crap out so you can start fresh.Concentrate on the ones that are not oozing. Charlie
FreeBeeTony
I was thinking that because the grease was coming out of the one corner, there wasn't enough pressure to come out the other sides.
jim redeker
I have a 1987 mercruiser 3.7L 165 with an Alpha One. How do I grease the u-joints?<br /><br />Jim
crazy charlie
the drive must be off the boat and the fittings will be plain to see within the ujoints.Charlie
FreeBeeTony,<br /><br />The way U-joints are treated is, Grease Must exit All 4 corners.... If 1 Doesn't, Squarely, Firmly, Rap the Opposite corner that IS loosing grease... Apply more pumps..If it works.. Great.. If not, Do it Again.... Continue till you get grease out All 4 corners..... <br />If this procedure Doesn't work... Replacement is the Next Step.....<br /><br />BTW, Your greasegun exerts about 2000psi.... You've got Plenty of Pressure.......
