DukeDelago
- Jul 17, 2009
- 46
When I trimmed down to change my prop shaft seal last week I noticed the u joint bellows was torn and water was getting in unwanted quantaties (hey, at least with the l-drive the hull still floats!!
). My question is: Can you change the bellows without removing the powerhead and dropping the lower assembly? It seems on paper that I could remove the lower unit, disconnect the tilt/trim cylinder and u joint housing, replace the u joint bellows and re-assemble. Anybody have any experience in doing this on an l-drive (120hp 1990). Any input would be greatly appreciated!!!
