U-joint bellows question
Beuford
Installed new u-joint bellows, applied grease instead of sealant, installed outdrive. Should i have used sealant instead?
Don S
Re: U-joint bellows question
What are we working on?
Beuford
2001 Wellcraft 2400 Martinique 5.0 Gi Dp-Sm !.95
Don S
Grease isn't sealant, but it will probably be fine as long as you put some grease on the nose of the drive so it doesn't push the bellows out of position.
Beuford
Boat will be in the water all season, going to pull outdrive off and redo, no big deal, just don't want any problems. What type of sealant should I use. Thanks for the input.
Don S
It just Permatex gasket sealer.
