U-bolts
ricksi
My trailer has 3/8" U-bolts for 1-1/4" pipe. The bolt width is 1-1/4" and the length is 4". I've searched trailer and bolt places for replacements and have not found them. Does anyone know of a place where I'd likely find them?
90stingray
Re: U-bolts
Have an axle and spring business bend some up for you... should be bout $10 a pair.
elkhunter338
Master Chief Petty Officer
Re: U-bolts
May try some exhaust u-bolts if you can find the right size. Can you get 1/2 x 1-1/4 If so just drill the hole out to 1/2.
jeeperman
Re: U-bolts
u-bolt for 1-1/4" pipe would be at least 1.66" in between.
1" pipe would be 1.315" in between.
rbh
Re: U-bolts
The only problem is they will be raw steel u-bolts.
I know they won't be hot galvinized dipped or anything, but it is nice to get a good 3/8 rod bent into a u-bolt than those idy bidy 1/4 inchers.
Hopefully they will hot bend them.
light sand, prime and paint.
