Magnum1500
- Jan 9, 2006
- 33
Is it OK to run SAE 80/90W extreme pressure (EP) Hyploid gear oil in V4 or V6 gearbox?
Yes, Its "OK"! For many years long ago, there was no such thing as Marine gear lube.<br /><br />Smart thing to do? Only if you change it regularly, at least twice a year and definatly at the end of the season.<br /><br />It can also, especially in newer engines with small gear cases cause a foaming issue if ran hard because of a lack of enough anti foaming additives. You can avoid these issues by using a synthetic gear lube though, and they will deal with moisture fine. MObil1, Royal Purple, Amsoil etc.Originally posted by Magnum1500:<br /> Is it OK
