Type C in 67 33 Johnson???
SeaMasterZ@aol.com
In examining my motor, I found a Use Type C sticker in the pull start access door, my motor is a manual shift, did they use type C in manuals for a while?<br /><br />I know that Type C is thinner stuff, used for the electric shift, and is typically like using ATF in a manual box, too thin, a prescription for disaster<br /><br />could it be a transplanted cowling or did they use C in manuals for a year or so?<br /><br />Joe Reeves, are ya out there???<br /><br />Thanks!
Joe Reeves
Re: Type C in 67 33 Johnson???
Ray.... You asked, and I quote "Joe Reeves, are ya out there???"<br /><br />Yes, I'm here, of course I'm here, I must be here. My wife says I'm not all there!<br /><br />Way back when Type "C" first came into existence, replying on memory here time wise, OMC and/or various mechanics used it in all shift setups.<br /><br />Within a very short time OMC issued a bulletin which ststed NOT to use Type "C" in the mechanical shift units as the lower viscosity resulted in having the lube sling away from various critical areas. This resulted in bearing damage, leading to of course the destruction of other inner lower unit componets.<br /><br />Bottom line.... Electric or Hydro Electric shift uses Type "C". Manual shift uses HiVis.
