Re: Two plugs don't spark
if you don't have a manual and a DVA adapter, the easiest way would be to swap the trigger leads on the switch box and see if the dead cylinders follow. Then try swapping the charge leads. Don't attempt to start it, just check for spark....<br /><br />You should have a manual to guide you...
