Re: twin outboards
been down this road a heap of times, if you have 2 X 70HP over 1 X 140HP, then Fuel is increased slightly, because of drag as mentioned before, but the 2 70's will have heaps more torque than the single, they will be slower than the single, but if you were to (say) tie the Boats together in a tug-o-war type of situation, the twins will pull the single backwards, no question about it, but you need a proper twin setup, 2 batteries, 2 fuel tanks, in fact two completely seperate setups, or you defeat the purpose, and then as mentioned, service costs are also to be taken into consideration, but you are servicing two smaller Motors rather than 1 big on, so the cost is not double, but it is more.
