My mileage sucks! 3 gpnm. I've got a FloScan/GPS to tell me the bad news. I've got an '86 Cruisers Esprit 337 express cruiser with twin Crusader 454s with aftermarket Holley carbs (650 cfm). The props are 17x20 4 blade (repitched when I bought the boat), original size as best I can tell. They sit in half tunnels. Boat is listed as 11,000 lbs, probably closer to 13K. The motors are old, the carbs are old (but were professionally rebuilt 3 years ago). I run 2800-3300 RPM typically, ocean use. 3300 RPM is 13-16 knots, depending on fuel load (up to 300 gal). Right after the carbs were rebuilt, I'd get .5 to .6 nmpg. It's down now to .35 to .4. Clean or fuzzy bottom makes only a small difference. The motor RPMs are very unstable starting around 2800RPM. One or the other motor will race ahead and it takes quite a bit of throttle tinkering to get a balanced 3000-3400 RPM. I first thought this was ventilation, but the speed picks up considerably as this starts to happen. Top speed when low on gas is maybe 20 knots at 3600 RPM. I don't know if the low RPMs is the wrong prop pitch (manuf says that's the original pitch) or a linkage problem (haven't checked this yet). From what I can tell of published performance reports of other boats, for the motors, weight and hull type, I should be getting twice the mileage and close to another 10 knots top speed.<br />I've just bought new Holley 80552 650 cfm carbs. I'll check throttle linkage and top RPMs with the new carbs in place. If I need to massage the props at all, I'm wondering if anyone can suggest which way to go, diameter or pitch? There's close to 4" of clearance between the prop and tunnel (the tunnel is also not quite symmetric around the prop, I think there's close to an inch less clearance at the top than at the sides) Do you think the runaway RPM problem is ventilation/loss of 'bite'? This is my first big boat and I'm fishing around to understand how to read these signs. This thing is eating my wallet alive!!
