Re: Turning V Hull
When that V-hull is leaning dramatically like that it is digging in better that the tri-hull will. It is just like a motorcyle. You don't want a boat to be turning flat unless it is a very low boat with a low center of gravity. Having a boat turn flat presents the possibility that it could rotate outward, causing it to flip. The best thing you can do is just run the boat and get used to how it performs. They used to have the 180 degree wheel turn full throttle test, which means you should be able to run at wide open and turn the wheel 180 degrees and the boat should handle that turn without sliding or skipping or any other horrid handling trait. The tri-hull, because of the outer sponsons, can't lean as much unless the hull design has a high deadrise amount to the center hull, then it will lean better. Flat bottom boats are the worst, if you try to turn too hard it can either come around on you or the prop blows out. In the end, just be safe with it.
