Re: Turning Point Props?
I have a Turning Point Hustler aluminum that I use on my Mercruiser #1 drive. i also have a Michigan wheel. The hustler is a 19" pitch and the Michigan is the same diameter but a 21 pitch. The cup on the hustler is nor ethan the 21 so the 19 runs almost identical RPM. I believe others have found this too. At least the aluminums run a little more cup than normal.
